Tool like Autoturn for Rhino
Is there a tool for studying vehicle turning incorporated into Rhino? If not, how do I go about it?
Thanks
this is not chat gpt, i have no idea what you are talking about, what is autoturn? pls be so kind to describe what you are after in just alittle more detail maybe someone not specialised in decrypting technical jargon language might be able to help then.
No there isn’t. You can analyse curvature but not swept areas. It should be pretty easy to create a Grasshopper program to do swept analysis but you wouldn’t have the vehicle dimensions database.
I presume you are working in an environment where you can’t just work to building codes for radius, width, camber etc.
Regards
Jeremy
