Good afternoon,
I’m trying to unroll a Brep in vb.net, or more accurately I’m trying to check if it is unrollable.
My issue is that the relativeTolerance does not seem to be taken in account, and a sligtly non linear edge always fail to unroll, while the same Brep is unrolled properly with rhino command using the same tolerance.
Do you have any idea on how to fix this?
Here is my code:
<System.Runtime.CompilerServices.Extension>
Public Function IsUnrollable(ByVal B As Brep, Optional ByVal tolerance As Double = 0.01) As Boolean
Dim U As New Rhino.Geometry.Unroller(B)
U.RelativeTolerance = tolerance
Dim unrolledBreps As New List(Of Brep)
Return U.PerformUnroll(unrolledBreps) > 0
End Function
and my test command:
Protected Overrides Function RunCommand(ByVal doc As RhinoDoc, ByVal mode As RunMode) As Result
For Each obj As RhinoObject In doc.Objects.FindByObjectType(DocObjects.ObjectType.Brep)
Dim MyBrepObj As BrepObject = TryCast(obj, BrepObject)
'Color in green is unrollable, red otherwise
MyBrepObj.Attributes.ColorSource = ObjectColorSource.ColorFromObject
If MyBrepObj.BrepGeometry.IsUnrollable(0.3) Then
MyBrepObj.Attributes.ObjectColor = Color.Green
Else
MyBrepObj.Attributes.ObjectColor = Color.Red
End If
MyBrepObj.CommitChanges()
Next
doc.Views.Redraw()
Return Result.Success
End Function
I’m attaching a sample model: Bug-Unroll.3dm (38.4 KB)
