Thanks again @jeff_hammond, just set this up here at home. Works great
Adding here your command+r Atom Keybinding, so I don’t have to scroll up when I set this up at work next Week.
Randy
Randy
Hi Jeff,
it took some time to get back to this. For some strange reason I only have access to my Macbook when my daughter is out of office or asleep.
I’ve updated Mac Rhino but now it won’t listen to Atom at all. Anyone else seeing this? I’m also having problems rotating the view like it used to work, so I guess I’ll have to wait for a new update…
[quote=“Jess, post:42, topic:15907”]
Hi Jeff,
it took some time to get back to this. For some strange reason I only have access to my Macbook when my daughter is out of office or asleep. [/quote]
haha.
[quote]
I’ve updated Mac Rhino but now it won’t listen to Atom at all. Anyone else seeing this?[/quote]
so you’re running the _StartAtomListenerCommand
? it turns off when you quit rhino.
did you update osx to 10.10.2?
if so, there’s something a little screwy between it and rhino right now… you can make it work right by changing the magic mouse preferences though.
discourse.mcneel.com/t/trackpad-10-10-beta-yosemite-beta/12183/26
Yes, I’ve updated OS X. The fix works - thanks.
Sure, see this screenshot. In the background you can see Rhino’s statusbar with the command feedback. Maybe this is also related to the OS X update? Maybe @Alain knows something?
hmm… yeah, i’m not sure what’s going on there (or, it hasn’t happened to me before).
Hi Jess,
What version of the rhino-python package are you using?
Hi Alain, there was 0.5.0 installed. No signs of an update. So I’ve uninstalled and re-installed the package, still v0.5.0 but then the update to v0.5.1 appeared and after installing it works again. Thanks!
0.5.1 wasn’t necessary and that’s why I released it as a patch (no update notification). 0.5.0 should be sufficient so probably the fact that you did a fresh install is what fixed your problem.
messing around… i’m sure this could be done better but just for fun using the default layer colors and the grid as a background image… a rhino syntax:
Ouch, that looks hard to read for me… I prefer something more “standard”, below is Notepad2, which I use for simple reading and minor editing of scripts, I have it set up to look much the same as the default Windows Rhino Python script editor color settings…
–Mitch
ha… me too. i’m working on a couple of scripts but no way would i want to do it with that color scheme… works ok for modeling… not so much for typing.
Having problems updating rhino-python in Atom.
Getting this message “EACCES, unlink ‘/Users/User_Name/.atom/packages/rhino-python/.npmignore’”
going from 0.5.0 to 0.5.3
Not sure where to look, googled lots of Linux stuff and js. Less stuff, developer related, here on work computer.
Any ideas. i just installed new build of Atom.
Randy
Hi Randy,
Do you have Atom 0.177.0?
I would try to unistall rhino-python completely and reinstall.
Not the cause of your install problems but one important thing I noticed today is that the latest autocomplete-plus package breaks rhino-python. If your installed version is greater than 1.1.0 then open a terminal window and type the following commands:
apm uninstall autocomplete-plus
apm install autocomplete-plus@1.1.0
Hi Alain,
Yes
I may uninstall Atom with an uninstall program like AppCleaner. Not able to uninstall packages.
Back in a few to let you know how things go.
Randy
fwiw, i’m not seeing that… after updating to atom.177 plus updating my packages, i restarted atom and rhino and autocomplete seems to be working ok .
Still getting unable to uninstall, after reinstalling Atom.
Am I missing anything?
I have done this twice, off in 15 minutes, so maybe a OS X restart in the morning and a new install of Atom. It seems to know about my packages after starting a new file from new install of Atom. Where would i look to uninstall all Atom packages other than what is listed in AppCleaner?
Thanks
there seems to be a hidden folder in the home directory…
~/.atom
shift-cmmd-G in finder and enter that
it’s the folder which opens when pushing the button at the bottom of this screenshot
(it’s where all your custom atom stuff is at )
Hi Jeff,
Not everything works. For example type:
import
on a new line and the completion window won’t pop up. Of course you can force it up with shift-ctrl-space.
It’s probably best to stick with autocomplete-plus 1.1.0 until I revise the package.
