Texture coordinates of a random point on a mesh
How can I get texture coordinates of a random point on a mesh?
Hi @rhinor,
Can you provide some background on why you want to do this? What problem are you trying to solve?
Thanks,
– Dale
I think what you are looking for is the Barycentric Coordinates of a point on the mesh and multiply those with the UV coordinates of the corresponding vertex texturecoordinates.
I made a quick setup to test t and it seems this is working.
Since I’m short in time it’s rather minimal:
If you run the python code in the attached file you can move the point around and see that the point coordinates equal the UV found on this 1x1 mesh with normalized mapping.
*I did no test with a triangulated mesh
Does this make sense?
-Willem
bary_test.3dm (459.4 KB)
import Rhino
mesh_id= [id for id in rs.NormalObjects() if rs.IsMesh(id)][0]
mesh = rs.coercemesh(mesh_id)
pt_id= [id for id in rs.NormalObjects() if rs.IsPoint(id)][0]
pt = rs.coerce3dpoint(pt_id)
mesh_point = mesh.ClosestMeshPoint(pt, 0)
mesh_face = mesh.Faces[mesh_point.FaceIndex]
uvA = mesh.TextureCoordinates[mesh_face.A]
uvB = mesh.TextureCoordinates[mesh_face.B]
uvC = mesh.TextureCoordinates[mesh_face.C]
uvD = mesh.TextureCoordinates[mesh_face.D]
bary = mesh_point.T
U = 0
V = 0
for b,uv in zip(bary, [uvA,uvB,uvC,uvD]):
    print b ,' : ',uv
    U += uv[0]*b
    V += uv[1]*b
uv_coord = (U,V)
print uv_coord
print pt
Thank you, Willem. The script works very well.
Hi Dale,
I was trying to use RayShoot method for placing points on a mesh, and retrieve hit points’ info. Any update on Whether RayShoot method works with meshes?
You might want to use MeshRay for that:
https://developer.rhino3d.com/api/RhinoCommon/html/Overload_Rhino_Geometry_Intersect_Intersection_MeshRay.htm
FYI:
Here is where you might want to wander around to search and find stuff like this.
https://developer.rhino3d.com/api/RhinoCommon/html/N_Rhino.htm
