TextObject alignment?
How can one change the alignment of the text of a TextObject?
There seems to be no rhinoscriptsyntax methods for this.
Not even to coerce the guid to TextEntity.
I also don’t see an enum or something that lists the DimensionStyles in RhinoCommon when I try to create the Rhino.Geometry.TextEntity.Create
WISH:
Could you please add text alignment to this method?
sc.doc.Objects.AddText(self: ObjectTable, text: str, plane: Plane, height: float, fontName: str, bold: bool, italic: bool, attributes: ObjectAttributes) -> Guid
from enum import Enum
class TextAlignment(Enum):
    Left = 1
    Center = 2
    Right = 3
    Justified = 4
Update:
Hey, I found it:
https://developer.rhino3d.com/wip/api/RhinoCommon/html/T_Rhino_DocObjects_TextDisplayAlignment.htm
But what are these?
[quote]
Normal 0 Normal alignment.
Horizontal 1 Horizontal alignment.
AboveLine 2 Above line alignment.
InLine 3 In line alignment.
[quote]
What about this?
:man_facepalming:
Every other software calls it TextAlignment but NO, Rhino will call it TextJustification :man_facepalming: :roll_eyes:
No, It is always Justification :slight_smile:
Hmm, apparently there’s something wrong with CAD tools :wink:
Text Processing tools call it Alignment:
CAD tools usage is “unjustified” :smiley:
Well, just to muddy the waters here, the ‘old’ definition of ‘justified’ (when I was learning some typography) was a block of type that was aligned both left and right. To do this you need to vary the letter spacing so that the line length is equal. Newspaper columns (if any of you remember what newspapers are any more) are still that way. Word processing and publishing programs do this… for example, Word:
Now these days we have left, right and center ‘justification’, but they really are ‘alignment’. Rhino is incapable of doing a word-processor, page layout style of ‘justify’ where it varies the letter spacing to make everything line up.
I always know it as justification and alignment related to the direction
That’s weird from cad tools :smile:
" Some modern typesetting programs offer four justification options: left justify , right justify , center justify and full justify ." from this wikipedia page. The use of the term Justification is thus quite justified.
Wikipedia Bible on the rescue :smiley:
There is a lot of false information there you know that right?
e.g. (existance of a so called Macedonian language) :rofl:
Sure, languages are always going to be a touchy subject, it’ll be down to who you ask. Minority languages have to fight hard for getting recognition - same as with Flemish, which can be considered either a dialect or a language.
Any information you find anywhere you should always regard critically. But we’re getting off on a tangent here now (:
Wordperfect at least used (uses?) Justification :slight_smile: but that was a long time ago I last used Wordperfect.
I base my understanding of Aligning the text to the Bulgarian word for that Подравняване which means exactly “arrange in a line” or “Align”.
Whilst, the word justify in my head means nothing of the sort. Justification in my head is equal to “reasoning”.
Hence it’s very unjustified :wink:
Yeah. This is probably one of those instances in English where the same word is, for some long-lost historical reason, used for two pretty unrelated or loosely-related things. Does Bulgarian have those? In any case, I suspect that Bulgarian must have a word to use when translating the typography related meaning of the English word “justify”.
Oh, plenty :smiley:, this is a region influenced by many cultures before and after the Ottoman Conquest of Bulgaria.
What is that meaning? Perhaps they have. I’m not a typographer, but I can check.
See this post from Mar 3:
yeah, you have that in Word as well, Justify. But that doesn’t explain why would Left, Center, Right be “justifications”
That in Bulgarian is двойно подравняване, meaning “double alignment”
History
Justification has been the preferred setting of type in many Western languages through the history of movable type. This is due to the classic Western manuscript book page being built of a column or two columns, which is considered to look “best” if it is even-margined on the left and right. The classical Western column did not rigorously justify, but came as close as feasible when the skill of the penman and the character of the manuscript permitted. Historically, both scribal and typesetting traditions took advantage of abbreviations (sigla), ligatures, and swash to help maintain the rhythm and colour of a justified line.
Its use has only waned somewhat since the early 20th century through the advocacy of the typographer Jan Tschichold’s book Asymmetric Typography and the freer typographic treatment of the Bauhaus, Dada, and Russian constructivist movements.
Not all “flush left” settings in traditional typography were identical. In flush left text, words are separated on a line by the default word space built into the font.
Continuous casting typesetting systems such as the Linotype were able to reduce the jaggedness of the right-hand sides of adjacent lines of flush left composition by inserting self-adjusting space bands between words to evenly distribute white space, taking excessive space that would have occurred at the end of the line and redistributing it between words. This feature is also available in desktop publishing systems, although most now default to more sophisticated approaches.
Graphic designers and typesetters using desktop systems also have the option, though rarely used, to adjust word and letter spacing, or “tracking”, on a manual line-by-line basis to achieve more even overall spacing. Some modern desktop publishing programs, such as Adobe InDesign, evaluate the effects of all the different possible line-break choices on the entire paragraph, to choose the one that creates the least variance from the ideal spacing while justifying the lines (so as to reduce rivers); this also gives the least uneven edge when set with a ragged margin.
That kinda supports my remark that should not be called “Justifications” but “Alignments” :smiley:
Well, yeah, but Justification is the historic term. However, we could also take a page from the French translation of Rhino which instead of the historic term ‘Loft’ uses ‘Surface par sections’ - Surface by sections - which actually better describes what it does.
I think we have gotten completely OT here though…
Yep, I also wondered why is it called Loft :smiley: isn’t Loft some kind of a building?
As a naval architect I know at least where Spline comes from :wink:
OT = Off Topic (ancient internet jargon)
Yep, it was the building where the ships were laid out. As a naval architect you should know that!
As ship design evolved from craft to science, designers learned various ways to produce long curves on a flat surface. Generating and drawing such curves became a part of ship lofting; “lofting” means drawing full-sized patterns, so called because it was often done in large, lightly constructed mezzanines or lofts above the factory floor.
