Hi.
I have tested if text fields works in VA annotation created through GH style.
If I bake VA text component, it’s converted to final result well.
Even though it’s placed at wrong position, it worsk.
However, it’s not converted to final result in VA annotation.
Text still remains same as one in text field.
Is there any way to make text in VA annotation work with text fields?
Thanks.
Hello @archist97,
This issue is already reported. I’ll keep you updated about it.
This is not possible for now (I’ll add it to the list), but you can have your text updated in Grasshopper and bake it when you are done changing values.
Yeah…We have already been doing so. I think this should be possible through VA.
Every VA object should work parametrically.
Thanks for adding this to the list.
@archist97 we have fixed the error about “Text is always baked with the Bottom-Left justification” in VisualARQ 2.12.4: https://discourse.mcneel.com/t/visualarq-2-version-2-12-4-released/
This issue is not related with Text Bake.
Thanks.
I’m referring to this comment, described above.
