Text Fields Self-Referencing User Attribute Text?
@jari.huuskola Rhino 6 is in maintenance mode only at this point. All new features will be in Rhino 7.
Hi @Trav .
Is it possible to implement (I assume in v8 only) new, let’s say service, non-editable AttributeUserText field representing container of text-based objects (leaders, text objects)?
It’s like reversed task of current topic.
It’ll be auto-updated after text edit.
For example:
It will let user refer this attribute and create dynamic combinations, based on other text objects.
User text is always editable so I don’t foresee a non-editable reference.
As for passing around the text of a text object, I would suggest putting the text in Document User Text and then making the text object reference that text from the DocumentUserText fx function.
Does Anyone have some sample blocks with Attributes, I’m just venturing into this section of Rhino & I’m checking out the sample video for blocks with attributes. I’m having trouble even making one, is there a library or some samples to follow?
Hi Sam
I’ve posted this example in the past:
Hello Wim,
Thank you for this, I have something similar made, but in the example that Mcneel put out, the text fields had more of an AutoCAD feel with individual fields. I was wondering how they made that.
Ill review the file and see if I can be more specific.
