I have a problem with the text fields: when I apply an Area Text field or a curve length text field to a curve I get a big number of decimals when I only want 2. The image below is an Area text field applied to a curve and it gives me 64.7059 when I only want 64.71.
I have the Unit properties set to 2 decimal points. I don´t know why it gives such a big number and we cannot give in our plans this way.
Thank you for your answer. Yes, I have the precision set to 1.00 for the dimension style I am using. Unfortunately that does not affect the text field…
I just checked with the developer. It’s a bug.
Since it is usually used in a dimension leader, it was intended to follow the named dimstyle setting as described above, but it is broken.
Hi! Thank you all for your replies. If this is a bug and it doesn´t follow the dimstyle setting, I suppose for the moment there is no solution to this, or am I wrong?
On the function list, Can coordinates be added? and when selecting element points to be able to select.
please refer to aatache image. hope this is clear.
Gon,
I thought this would be straight forward. all I want to achieve is with the text functions, to be able to read the coordinates of a point. in the points properties windows the coordinates are displayed and with the text functions I would like to read them.
Could it be that this isn’t fixed for BlockAttributeTexts? The annotation style used has the right precision (0.00) but it isn’t displayed that way. Also I don’t understand how to change which polyline is linked to the area text. In a regular text field i can just press the fx button, but how do i do that in a block? The little fx button next to the Value isnt pressable, if i use the one on top it just creates a completely new key.
Is there maybe a way to specify rounding for individual text fields? I have a room tag similar to Jasper’s, linked to object dimensions. I’d like to create a single text box (with a text frame to avoid making blocks) referring to multiple units and rounding. eg. 3000mm, 3.000 m, 9.5 m². Something like…
