I have written a very simple C# node to test a line length then divide with points based on results. When I plug in multiple lines and try to pass through a stream filter it’s failing.
Am I missing a graft? Or is something more required in the C# node?
See attached.
Thanks,
Dan
test.in.bounds.divide.gh (9.2 KB)
I think the problem is just with Stream Filter, it doesn’t do what you need it to do.
The error is: Filter component can only operate on a single Filter Index value.
In this particular case, it may be easier to just output the number of divisions from your C# script directly:
Not only fewer components, but also a lot less work being done per solution.
David,
Thank you for your help. I’m clearly just getting my feet wet with C#, the support on this forum is much appreciated.
Dan
Sadly my solution doesn’t scale to all problems of this type. I can’t think of an easy way to do what you originally tried to do.
