System requirements Grasshopper
Hello.
What are the requirements the Grasshopper to computer? How many it requires hard disk space? Nowhere I can not find the information.
Thank you!
If your computer runs Rhino, it will run Grasshopper. It may not be fast, but it will run. Grasshopper requires a few megabytes on the disk to be installed.
I got it. Is Grasshopper operate normally with 2 GB of RAM, what do you think?
If you have a 32-bit OS then 2GB is all you get anyway, and Grasshopper can run just fine on that, although you may run into trouble if you’re generating lots of data. On a 64-bit OS it should still run, but I’d highly recommend getting at least 6~8 GB in that case.
I got it. Thank you!
