Symmetry Bug
Bug_Symmetry.3dm (86.9 KB)
I’m making a repeating pattern and attempting to use one control tile. My goal is to set up Symmetry on 3 sides, then mirror and array them. I can only add Symmetry on two sides before it begins to behave poorly.
Adding symmetry to the third side doubles the width of the parent surface.
The surface is no longer editable, but the 3rd side will match the double width of the parent.
Hello - I see that, thanks.
-https://mcneel.myjetbrains.com/youtrack/issue/RH-47374
