Hi Lander,
To be honest, I don’t understand, so could you explain. What do you mean? Can you back that assertion up with evidence that can be used to make things better?
Regards
Jeremy
Hi Lander,
Regards
Jeremy
Jim proved it. And through studying the many things that he’s said, I’ve realized he’s 100% correct about ‘fillet edge’ being the wrong approach.
I’m not sure if my perception of the matter is exactly the same as his, but he helped me realize there’s definitely a problem with ‘constraining’ fillets to be driven by ‘edges’ – especially when Rhino does such a bad job dealing with the edges and leading to failures.
I suppose, if you allow the failure to output something, by turning off the ‘trim’ aspect, then you get something to play with. So, it’s all relative.
Maybe it’s time for another ‘filletedge’ failure review.
Thanks for expanding. So, if I understand you right, when you say
you mean just bad in the context of filleting: there isn’t a raft of other types of bad edge behaviour you’re aware of. Because that would be scary.
My use of the word ‘edge’ in that context was intended exclusively for the ideology behind the command ‘filletedge’ and it’s malfunctions of managing the transformations necessary, to edges, and adjacent edges/faces thereof, in order to succeed in said command of filleting ‘edges’.
Jim has proven, to me, that the ideological constraint of fillets being driven by edges, is a flawed ideology.
I used to be a firm believer in edges being the way to define them, but through much research and studying I’ve changed my mind. Unfortunately, the technology to work around this is still underdeveloped.
Jim’s script shows much promise, but in the meantime there’s still much review to be done overall, in terms of automation and all possible scenarios – not just faces that are ‘tangent’ per say.
Thanks for clearing that up - you had me worried there for a few moments!
