Surface parameterization
In RhinoCommon we can set domain to a surface e.g.
surface.SetDomain(0, new Interval(0, 1));
Is there a backwards operation to retrieve original domain before normalizing it?
I think this is what you’re looking for:
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Surface_Domain.htm
-Kevin
Nope, if a surface is already normalized, this returns [0-1].
I am wondering how the initial domain is computed.
Depending on what you want to do, you could probably just store its domain in a temporary variable, before reparametrizing it.
Hi @Petras_Vestartas,
You should not need to normalize the domain of curves and surfaces.
I’m sure I’ve posted this before:
Poorly parameterized objects may not intersect and trim properly when combined with other objects. “Poorly parameterized” means the curve’s domain or the surface’s u or v spaces are tiny or huge compared to the size of the object.
When curves and surfaces are paramterized with a [0,1] domain, both the accuracy and the precision of geometric calculations like intersections and closest points are reduced, sometimes dramatically. Ideally the domain of a curve is close to it’s length and the domains of a surface is close to is average breadth in the appropriate direction.
We try to have parameterization match the length of a curve or some measure of the width of the surface. Derivative information is better if we do it this way.
To convert interval value to normalized parameter, use Interval.NormalizedParameterAt.
To convert normalized parameter to interval value, use Interval.ParameterAt.
– Dale
Hi @Petras_Vestartas, from the size of the surface eg. try like below:
import Rhino
import scriptcontext
def DoSomething():
    brep_id = rs.GetObject("Surface", rs.filter.surface, True, False)
    if not brep_id: return
    # for single faced breps only
    brep = rs.coercebrep(brep_id, True)
    if brep.Faces.Count != 1: return
    rc, width, height = brep.Faces[0].UnderlyingSurface().GetSurfaceSize()
    if rc:
        interval_u = Rhino.Geometry.Interval(0, width)
        interval_v = Rhino.Geometry.Interval(0, height)
        brep.Faces[0].SetDomain(0, interval_u)
        brep.Faces[0].SetDomain(1, interval_v)
        scriptcontext.doc.Objects.Replace(brep_id, brep)
DoSomething()
it should give equal results like using _Reparameterize _Automatic on a surface.
_
c,
@clement This Indeed answers my questions. Thank you.
Also thank you @dale I was always setting domain to 0-1 without too much thinking, which seems not be a good practice.
@diff-arch Thank you too.
