The most intuitive implementation would be to use a brute force algorithm. Under the assumption that list A is always larger than list B, you can check for all the possible ways to divide list A into a number of N sub-lists, where N is equal to the number of elements of B.
Then sum over the sub lists and compare to B
Note: this brute force algorithm is only feasible when the number of elements in list a is not terribly large, since we are dealing with permutations.
def sorted_k_partitions(seq, k):
"""Returns a list of all unique k-partitions of `seq`.
Each partition is a list of parts, and each part is a tuple.
The parts in each individual partition will be sorted in shortlex
order (i.e., by length first, then lexicographically).
The overall list of partitions will then be sorted by the length
of their first part, the length of their second part, ...,
the length of their last part, and then lexicographically.
n = len(seq)
groups = [] # a list of lists, currently empty
def generate_partitions(i):
if i >= n:
yield list(map(tuple, groups))
else:
if n - i > k - len(groups):
for group in groups:
group.append(seq[i])
yield from generate_partitions(i + 1)
group.pop()
if len(groups) < k:
groups.append([seq[i]])
groups.pop()
result = generate_partitions(0)
# Sort the parts in each partition in shortlex order
result = [sorted(ps, key = lambda p: (len(p), p)) for ps in result]
# Sort partitions by the length of each part, then lexicographically.
result = sorted(result, key = lambda ps: (*map(len, ps), ps))
return result
note: seq is A, k is len(B)
afterwards, sum each and compare to B
