Box edit is a very useful tool for transforming objects precisely, specially the individual option. few things can make it more versatile like-
- currently we have only one checkbox which let you make 1D or 3D transform not 2D.
- when we check on Uniform, the transform happens only by X values to all axes and other options are greyed that is ok but it will be useful if we check all three box and change either x,y or z values and rest two axes change proportionally.
like if i change x from 1 to 2 then Z should change from 4 to 8 and also if i make change in Z then the value of X should be change proportionally.
