I have a list of many groups with “True” and “False”, and I want to get sublists for each “True” group and their index in the original list. How can I do it without programming?
thanks
thanks
Sift Pattern does this:
thanks for the tips, but my wish is to get 2 sublists from atteched example, one from index 0 to 5, one from 9 to 16. And the result is randomly from last step, that means there counld be more than 3 sublists.
How do you make the labels above the components that show where they are located in the menus?
-Kevin
Thanks @eddi
Looks like a useful plug-in, but unfortunately does not seem to work on Mac.
I see that it’s not listed as Mac compatible, but many plug-ins listed as Windows only work with the more current versions of Rhino/Grasshopper for Mac.
-Kevin
Dear Kevin,
i think is compiled only for Win-System, developer uses *.dll calls, specific for Windows.
@anon39580149 you get my point, but I still need to remove the branches with 0
this calculation is for this purpose Direct Sun Analysis with more restrict - ladybug-tools - Ladybug Tools | Forum
similar numbers.gh (16.3 KB)
@eddi thank you all the same, your example is good to study
@anon39580149, you save my day! I get what I want, but 2 more issues for later thinking
the index I wanna get are those take part of the last result. I extend the input to a larger list, that you can understand better. atteched file for example, I wanna get the index of those 35 items
similar numbers.gh (26.9 KB)
this one better, the result is from 2 segments.
in the process, some segments may be remove out of the calculation. The index should also be cutted. I will use this to visualize the geometry(show/hide)
I don’t understand what you want and the steps in your script,
you must explain better from the beginning
ok, maybe it’s a strange rule or code, there’s stength controlling rule in china for the residential community planning, the direct sun hours in special day, 12.21 or 1.21, basically 2 hours. But different cities have some more details about the calculation. First of all, the timestep, almost 1 min or 5 mins. then the amount of continued segments. with the ladybug component it is not easy to get the accurate result, i need to do some post processing with the sunpath component of ladybug. for the test point, i need visualation with sun vectors as lines according the rules. further, i want get the simalar visulation like the direct sun hours analysis component with colorful meshes. for the Construction application there are Official Certificed programs, my idea is to get satisfied proofing in rhino for the concept phase without risk for later proofing with the official programs. Those rules are inherited from old USSR, which for me is absolute nonsense.
