I’m mucking around with creating sub-d surfaces and it looks like there are different line thicknesses depending on an edge or crease, not really sure what I’m looking and whether I’m missing a step to get it to where it should be, for example converting an edge to a crease.
It’s just not clear what types of lines I’m looking at in this situation. Sometimes it’s difficult to distinguish if it’s an edge, or a crease or two lines that need stitching, or just two lines that are so close and need to be brought closer together at vertex points?
The darker edges are creased edges. Use Tab to toggle between smooth and flat display of the SubD if you are wondering about two edges being close to one another. They may look like one edge in flat mode but smooth will show them apart.
