I find the creation of Text Fields takes a lot of clicks.
It takes 9 clicks to place an attribute user text. The process fails if a curve is preselected.
Unless I’m overlooking something, there’s no option to create text fields through the command line and the intended way is through the Text
command. So the only way to make the process quicker would be a scripted command?
Or can it somehow be done with a macro?
The test command mentioned by @wim in this topic is helpful:
In an example with two curves with user text, I placed one text manually and used TestMatchAnnotionFields
to create the second one.
9 clicks for the first text and 3 for the second one…
Placing an area dimension takes 5 clicks going through the menu and 3 clicks if the command is entered in the command line.
I think a textfield command which is accessible in the command line would be nice. It could then hopefully be used with preselected geometry.
two_curves_with_user_text.3dm (38.0 KB)
