Hi ,Work In Progress
(8.0.23234.12305, 2023-08-22) see the 2 shots , same object in rhino7 and rhino 8
Is there something wrong in perspective ?
Thank you for suggestion,It is an imported object and there is a circle. The object is a subd. if a select the circle the problem begins . I read something about aoutocplane command .I tried to disable it. Am i rigth?.
You can disable the AutoCPlane by typing _AutoAlignCPlane and then e or click Enabled so it ends up saying Enabled=No
