Strange behavior using Monochrome
Over 5 other similar drawings only one shows this strange traces when I am using “Monochrome” or “Artistic”.
I take it you are referring to the triangulation and not the cyan lines. If you save one of the triangulated surfaces as a new model, does that model show the same behaviour? If so, please post it here - it is much easier to diagnose something if you can wrestle with it!
Hello Jeremy,
Sorry. You are right its about strange triangulation and not cyan lines. I insert the 3dm file with only one forward piece. If you need more please let me know. The file is quite large.
Regards
27 Front new.3dm (230.7 KB)
The strange artefact is appearing because you have a polysurface comprising two seemingly identical surfaces included in the group. Exploding the polysurface and deleting one of them causes the group to display without the triangles.
In fact once you explode the polysurface the group displays correctly even if you don’t delete the superfluous surface.
HTH
Jeremy
p.s. This is probably a bug and not spotted in development because the circumstances are unusual.
Many thanks for your reply. I just rebuild the hole stuff and triangles are gone. Thanks again.
