Hi all,
I have several surfaces I have to split with curves within a grasshopper python component.
I think I have managed to split them and the result are breps. However, I need these breps inside the component to be surfaces/polysurfaces (I can’t output them and use a different component) but I don’t know how to convert them via script. Possibly due to my limited knowledge of Rhino Common.
See image and script below, should describe better what I am trying to do. Any ideas?
Thanks you so much in advance
- surfaces contains all surfaces to be split (guids)
- cuttercurves contains all curves used to split the surfaces (guids)
cut_surfaces_breps = [ ]
for surface in surfaces:cutter_elements = [rs.coercecurve(curve) for curve in cuttercurves] brep = rs.coercebrep(surface) split_brep = brep.Faces[0].Split(cutter_elements, 0.01) cut_surfaces_breps.append(split_brep)
- how do I convert all cut_surfaces_breps to surfaces?
The image belows shows cute_surfaces_breps, but I need this to be as polysurfaces/surfaces within rhino
