Is it possible there is a bug in the Split command for Breps in python?
I am splitting a Brep (Rhino.Geometry.Brep object) using the brepName.Split(surfaceName) command.
When I ask either of the resulting breps for their domain, I end up with the u,v, domain of the original Brep. This should not be, right? T
he same goes for the BrepFace.Split command.
The resulting BrepFaces have the original breps domain.
I only need the domain of the resulting splitted breps.
Hi Lukas- splitting a surface into pieces does not alter the underlying surface size - each resulting face will still have the original underlying surface unless it is shrunk (Rhino command: ShrinkTrimmedSrf).
I wasn’t aware that I have to shrink the face before the domain would update.
I am not sure if this is intended.
Anyways when I split the brep, and access its face, it will still have the domain of the unsplit brep.
I start with a surface.
I then randomly generate a point on this surface (using the domain and u,v coordinates)
Then I put a line through this point and split the surface.
I do the same for each of the two newly generated surfaces. But to find a point inside the new surfaces I need to have the correct domain.
