I’m looking for a way to easily split merged edges at tangents/Quad points. I use MergeAllEdges all the time but anywhere I have tangent edges (ie. Interior loop with fillets) MergeAllEdges also tries to join the tangent edges into a single edge. In Rhino this is fine, but not for importing into FEA software for meshing. I’d like to be able to either:
merge only edges that are parallel,
or be able to go back and split the edges at tangent/quad points after running MergeAllEdges.
Is there an easy command or set of commands I could use to script this or do I need to dig into Rhino Common to figure out how to brute force this?
Rhinoscript (python) does not have something to change brep edges. But you can find it in RhinoCommon and use it if you know the points where to split. For point 2 above, you might check out this
_
c.
