Hi!
I need to split an object using a line and delete the left side. How can I do it automatically using the python script?Example.3dm (65.4 KB)
Moved to Scripting category so it will be seen.
Let me know if this code sample is helpful:
# Split a curve with a cutting curve
def test_split_curve():
# Select the curve to split
curve = rs.GetObject("Select curve to split", rs.filter.curve)
if curve is None: return
# Select the curve to use as the cutter
cutter = rs.GetObject("Select cutting curve", rs.filter.curve)
if cutter is None: return
# Intersect the curve with the cutter
intersection_list = rs.CurveCurveIntersection(curve, cutter)
if intersection_list is None: return
# Look for point intersections
parameters = []
for intersection in intersection_list:
if intersection[0] == 1: # point
parameters.append(intersection[5]) # first curve parameter
if len(parameters) == 0: return
# To split a closed curve you need at least 2 parameters
if rs.IsCurveClosed(curve) and len(parameters) < 2: return
# Split the curve
rc = rs.SplitCurve(curve, parameters)
if rc:
rs.DeleteObject(curve) # optional
# Check to see if this file is being executed as the "main" python
# script instead of being used as a module by some other python script
# This allows us to use the module which ever way we want.
if __name__ == "__main__":
test_split_curve()
– Dale
Thank you very much!! It’s perfect.
Matteo
