Hi there, just got Rhino on my Mac. I am used to drawing in Autocad and Turbocad. I cannot figure out how to specify the length of a line or radius/diameter of a circle etc. Please advise.
Try this:
Start to draw your item, to the left there will be a column with various selections for inputs. One of them should suit your needs.
Cheers!
Start your line, type a value for length (this will be recognized automatically, no need to click the input field), position the line and confirm by setting a point. For a circle, setting the mid point and typing a diameter is sufficient.
Max.
Thanks, how do i specify the angle of a line?
Pretty obvious, click the “Angled” option and follow the instructions.
Sorry but I’m finding it extremely frustrating as I am new to this software.
I select angled line.
Type in 0 for the starting point.
Press enter.
End of base line is the next option.
I type in 50 which i would assume is the length of the line.
Press enter.
For pivot angle I type in 45 which would be the angle of the line.
Press enter and I get nothing.
and I’m attempting this in the “top” viewport.
I’ve never used Angled Line but the normal.
Try:
- Type line
- press 0 and enter
- type <45 (< means under an angle and 45 degrees) and enter
- type 50 (thats your length) and enter and click too accept
2nd way is:
- Type Line
- Press 0 and enter
- use coordinates like @50,50,0 (@X,Y,Z (@means from current location)) press enter
Cheers
This is where you go wrong. With “End of base line” you only have to specify the base line direction by setting a point. Then you specify the angle of your line (relative to the base line angle), and after that the required length. The last action is setting a point to define the direction (two possibilities).
Max.
thanks
