Hi guys,
I’m struggling with the special number, as you can see there are numbers which basically should be rounded correctly but somehow for item index number 3 results came differently. I presumably think that the actual data might be like 3.9999999… but grasshopper shows it as 4.0, so it was rounded to 3 instead of 4 because it’s floor rounding. If in that case how I can extract only the integer?.
By the way, I’ve tried round up as well but it will effect results if the data contains the number that has over 5 value on decimal digit likes 5.7 will become 6.
