Sorting planar Line-like curves and curves
Hello, I am trying to figure how can we sort straight line and curves separately from a complex planar shape in grasshopper ? like in the ref. image below
I tried “Evaluate curve” and “Curvature” components but I guess they are useful to evaluate only on a particular point/parameter on the curve.
Basically, I am trying to sort curves with some curvature and the straight lines (with no curvature).
by sort you mean seperate.
sort is like 2 1 3 to 1 2 3
seperate is like 2 1 3 to 2 1 and 3
curvature is good
evaluation on curve mid point is enough in your case.
you do not neet do evaluate infinite points on curve.
for a more stable way:
you may want to use similar instead of equal depends on your curve.
ohh nice good to know this approach. Thankyou :slightly_smiling_face:
Yes, wanted to seperate it according to the type. Thank you for sharing the two approaches. Good to learn these different logics.
