I need the array of curves as per last frame of video… only the curves segments INSIDE the boundary curve…
this seems like it should be simple, but its had me at it for hours now going nowhere
Any pointers please?
input is a curve, and an array of curves
as so:
RhinoGet.GetOneObject(“Select Border Curve”, true, ObjectType.Curve, out InputCurve);
if (null == InputCurve) return Result.Cancel;
and an array of curves generated to fit in its bounding box
List CurveArray = new List();
int count = (int)(YLength / PanelTolerance);
for (int i = 0; i < count; i++)
var xf = Transform.Translation(translateVector);
arrayline.Transform(xf);
CurveArray.Add(arrayline.ToNurbsCurve());
video probably easier to explain that the message.
