Lara4747
(Lara)
April 25, 2024, 11:44am
1
I’m a school student struggling with grasshopper - especially with the solid difference/intersect tools. I’ve cut two geometries out of each other below - but I wanted to keep the middle portion, instead of deleting it. Any help would be great - I’ve attached my grasshopper script below.
solid difference - test.gh (20.6 KB)
Piotr
April 25, 2024, 11:52am
2
What do you mean by middle portion?
You mean this?
Lara4747
(Lara)
April 25, 2024, 11:57am
3
yes that’s the part I wanted to keep! Minus the wall on the left hand side
Piotr
April 25, 2024, 11:58am
4
Your top element is not long enough to cover the wall:
Lara4747
(Lara)
April 25, 2024, 12:04pm
5
Is there any way to create a surface out of the polyline and the curve in my script? So I can cut that out instead of the extrusions?
Piotr
6
To get it solved you have to replace intersection with solid difference:
I don’t understand this triangle creation so you have to fix it yourself first.
Piotr
April 25, 2024, 12:06pm
7
The curve needs to be flat and closed but I don’t understand how this could be of help here?
Adam_M
(Adam Mounsey)
April 25, 2024, 12:08pm
8
Lara4747
(Lara)
9
I want to make this shape a surface, rather than having two surfaces which extrude upwards and downwards - does that make sense?
Piotr
April 25, 2024, 12:10pm
10
You can extend the upper curve for larger triangle.
Piotr
April 25, 2024, 12:13pm
11
You can use loft, but you still need to extend the upper curve for the effect you want:
Lara4747
(Lara)
April 25, 2024, 12:21pm
12
Any chance you can send me the script? I’m not sure I understand
Piotr
April 25, 2024, 12:33pm
13
Ar you happy with my solution? Adam proposed another one and there is no clear information (sketch?) what are you after.
