I have a series of surfaces and I’d like to select only the ones which have an larger area than 50 m and smaller than 350, is it possible?
Thank you so much!
Area.gh (18.2 KB)
I dont have one of the plugins you are working with, so dont have your surfaces, but you can do something like this:
Use an And Gate to combine the results of Larger Than/Smaller Than. Connect both the Larger Than and Smaller Than components to the Area (at the moment, you are connecting this Larger than component to your filtered list of surfaces), and then connect this to the Dispatch pattern.
