hey ladies and gentlemen I’m have an issue with shrink wrap with a particular file and i for the life of me cannot get a good mesh after shrink wrapping several times with different iterations specs.
slice 1 shrink wrap.stl (15.3 MB)
is that giving you a good mesh on check mesh wizard?
i used
target edge length .02
o offset
0 smoothing
10 polygon optimization
check - fill holes
this is the check mesh results after inputing the settings you posted. also thank you for your reply!
why even shrinkwrap that? it has only a few small problems that can be fixed with deleting a few faces and patching them back in…
check this video for how to do this-
slice 1 shrink wrap_kfix.stl (15.3 MB)
that mesh will print fine. The reporter on that tool gets a bit dramatic…
you just don’t want holes or normals that are screwed up.
you can fix normals with the command unifymeshnormals
check the mesh with selopenmesh
Thank you sir! i will send to the printer to test er out and post results! thanks guys!
