Hello.boy,i also have this problem, can you post your way?or post a example to display zebra
I just noticed, that Dale’s addition appeared in the Rhino 7.4 SDK (see below). It works fine! I will also add a small video how it works in my function.
CRhinoDisplayPipeline::DrawZebraPreview(
const ON_Mesh* mesh,
const CRhinoZebraAnalysisSettings& zas,
const ON_Color& color,
CRhinoCacheHandle* cache
Mhm, I can’t upload my video format so I will just upload 2 screenshots. It is a function that can smooth selected areas from a mesh - they show the mesh before and after smooth with zebra stripes.
I have a similar effect - using a striped texture on a mesh during a dynamic draw, as a visual feedback for the main tween-edit functionality.
So far, it’s used in the TweenerAddControl function in Tweener | Food4Rhino and done with pure C#, works fast enough since only the mesh vertex texture list needs to be updated in each draw.
However, it would be great to share some “zebra-controlling” code.
Hello @dale ,
is it possible to set zebra preview strip size and direction without zebra analysis mode in C#? I have found its using last settings from analysis. Could I override them?
Łukasz
EDIT:
I see c++ gives such opportunity but similar setting is missing in RhinoCommon
Is it possible to add this also there?
https://developer.rhino3d.com/api/cpp/class_c_rhino_zebra_analysis_settings.html
Hi @mlukasz87,
No, the Zebra settings class, CRhinoZebraAnalysisSettings is not exposed in RhinoCommon yet.
https://mcneel.myjetbrains.com/youtrack/issue/RH-64442
– Dale
Thank you @dale. It works fine in latest SR8. Only stripe thickness description is reversed but it is not a problem.
