Shapediver Plugins Not Supported (Hops & Conduit)
Hallo!
At the moment, I am working on a project with Hops component that can load machine learning model and Conduit plug-in to visualize real-time data. I want to export this grasshopper file into Shapediver. Unfortunately, Hops and Conduit are not supported by Shapediver.
Is there a work around to use these plug-ins in Shapediver?
I attached my grasshopper file below.
Best,
Felita
Hops Heating Data Viz.gh (532.9 KB)
Conduit is a plugin for data visualization which will not work with ShapeDiver. The charts and graphs you get with this plugin will not make it to the online platform. You will need to output the naked data and build or use data visualization tools for the web if you want to replicate the plugin functionalities in a web browser. We will add some built-in data visualization tools to the platform in the future, but there is no defined schedule for these features yet.
When it comes to Hops, I am not sure how you are using it exactly, but if you load a machine learning model from an external software or URL, this will also be problematic when using the shared ShapeDiver system. This is a projects that would require a discussion with our team and the setup of a dedicated system with the installation of additional software that we cannot enable in the standard shared system.
If you are interested in knowing more, contact us to discuss your project.
