I have attached one of the files I tried to import with this message. If you have looked at the above definition- could you please tell me if the setup I’m using for point selection is correct?
Also, as I asked earlier is their any solution/alternative to the high computation time of quad remesher component?
Hi @mathieu1 , I have with multiple definitions tried to use internalized points (even without the points input interaction component) but for some reason shapediver doesn’t recognize the points, until and unless I use some internalized mesh to create a point (centroid/curve middle).
Not sure if this is related to the bugs you’re already working on - Was this always the case or something that has come up recently?
