Hi, I (still) seem to have a problem with a custom component I made, that should output a datatree (storing block - parcel relationships). I get a Null Exception at
DA.SetData(0, dataTree);
What is going wrong here?
public class TestDataTree : GH_Component
public DataTree<GH_Curve> dataTree = new DataTree<GH_Curve>();
public List<int> nrOfParcels { get; set; }
/// <summary>
/// Initializes a new instance of the C_TestDataTree class.
/// </summary>
public TestDataTree()
: base("Test that Tree", "x",
"x",
"Tryout", "Optimisation")
/// <summary>
/// Registers all the input parameters for this component.
/// </summary>
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
pManager.AddCurveParameter("Blocks", "Blocks", " Add the blocks within which the parcels are located.", GH_ParamAccess.list);
pManager.AddCurveParameter("Parcels", "Parcels", "Add the parcels as polyline curves.", GH_ParamAccess.list);
pManager.AddCurveParameter("Buildable Parcels", "Buildable Parcels", "Add those parcels that are buildable (not predefined as green spaces or similar, optional).", GH_ParamAccess.list);
pManager[2].Optional = true;
/// <summary>
/// Registers all the output parameters for this component.
/// </summary>
protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
pManager.AddGenericParameter("data Tree", "data Tree", "data Tree", GH_ParamAccess.tree);
/// <summary>
/// This is the method that actually does the work.
/// </summary>
/// <param name="DA">The DA object is used to retrieve from inputs and store in outputs.</param>
protected override void SolveInstance(IGH_DataAccess DA)
InitializeDataTree(DA);
/// <summary>
/// Provides an Icon for the component.
/// </summary>
protected override System.Drawing.Bitmap Icon
get
//You can add image files to your project resources and access them like this:
//return Resources.IconForThisComponent;
return null;
/// <summary>
/// Gets the unique ID for this component. Do not change this ID after release.
/// </summary>
public override Guid ComponentGuid
get { return new Guid("686e3dc4-9bc4-4e5f-ae1c-353d6f4fbfbe"); }
public void InitializeDataTree(IGH_DataAccess DA)
// read in blocks, conversion check
List<Curve> _blocks = new List<Curve>();
DA.GetDataList<Curve>(0, _blocks);
List<GH_Curve> BlockCurves = new List<GH_Curve>();
foreach (object item in _blocks)
if (item != null)
GH_Curve curveGoo = null;
if (GH_Convert.ToGHCurve(item, GH_Conversion.Both, ref curveGoo))
BlockCurves.Add(curveGoo);
// read in parcels, conversion check
List<Curve> _parcels = new List<Curve>();
DA.GetDataList<Curve>(1, _parcels);
List<GH_Curve> ParcelCurves = new List<GH_Curve>();
foreach (object item in _parcels)
if (item != null)
ParcelCurves.Add(curveGoo);
// read in buildable parcels, conversion check
List<Curve> _buildParcelCurves = new List<Curve>();
DA.GetDataList<Curve>(2, _buildParcelCurves);
List<GH_Curve> BuildParcelCurves = new List<GH_Curve>();
foreach (object item in _buildParcelCurves)
if (item != null)
BuildParcelCurves.Add(curveGoo);
List<GH_Curve> myParcelCurves = new List<GH_Curve>();
// check if information on buildable areas has been passed by user, use respective curve collection
if (BuildParcelCurves == null) myParcelCurves.AddRange(ParcelCurves);
else myParcelCurves.AddRange(BuildParcelCurves);
for (int i = 0; i < BlockCurves.Count; i++) //for each block create path and fill in GH_Curve
Polyline block;
bool cast = BlockCurves[i].Value.TryGetPolyline(out block);
if (cast)
GH_Path pth = new GH_Path(i);
dataTree.Add(BlockCurves[i], pth);
else { Exception e = new Exception("Block at index " + i + " is either invalid or not a polyline."); }
int parcelPathIdx = 0;
for (int j = 0; j < myParcelCurves.Count; j++) //for each parcel check if in block, if yes, append to data tree
Polyline parcel;
bool cast2 = myParcelCurves[j].Value.TryGetPolyline(out parcel);
if (cast2)
if (IsInside(parcel.CenterPoint(), block))
GH_Path pth2 = new GH_Path(i, parcelPathIdx);
dataTree.Add(myParcelCurves[j], pth2);
/* child node of type List<GH_Number>, stores building parameters
List<GH_Number> buildingParams = new List<GH_Number>();
GH_Path pth3 = new GH_Path(i, parcelPathIdx, 0);
this.DataTree.AppendRange(buildingParams, pth3);*/
parcelPathIdx++;
else { Exception e = new Exception("Parcel at index " + j + " is either invalid or not a polyline."); }
int parcelNr = parcelPathIdx++;
nrOfParcels.Add(parcelNr);
//method that checks if point is inside curve
public static bool IsInside(Point3d _pt, Polyline _crv) { //... }
