_SelSameName?
Would there, could there be a macro for selecting objects with the same name?
Currently -Selname Select does not work with preselection
Hi Toni - - scriptable -SelName Select Enter with pre-selection should work - as it does with
-SelLayer Pick Enter
, but does not. Not to mention the option name should match. Thanks for pointing this out, I’ll see if we can get it fixed.
Hi @Toni_Osterlund,
Here is a Python script that may help.
SelSameName.py (592 Bytes)
– Dale
Thanks @pascal @dale
So python it is.
I re-wrote Dale’s idea to a button.
Seems to work. Good for now.
_NoEcho _-RunPythonScript (
#! python 2
import scriptcontext as sc
def SelSameName(objs):
    rs.EnableRedraw(False)
    names = []
    for obj in objs:
        name = rs.ObjectName(obj)
        if name != None:
            names.append(name)
	if len(names) > 0:
		for rh_obj in sc.doc.Objects:
			for name in names:
				if rs.ObjectName(rh_obj) == name:
					rs.SelectObjects(rh_obj)
    rs.EnableRedraw(True)
selection = rs.SelectedObjects()
if len(selection) == 0:
    selection = rs.GetObjects("Pick objects",0,False,True,True)
    if not selection: Exit
SelSameName(selection)
