hi guys,
i would like to select the arcs that are close to the poinnt as in the picture.
cant figure on how to do it.
can you please help me?
thanks a lot!
unnamed1.gh (226.5 KB)
hi guys,
thanks a lot!
Try to use the Connect Curves component to achieve it
This means that you need to adjust the order of some curves in the lists.
Reverse curve component? Or maybe sort along curves component and then use shift list?
Yes you are right, you can use the Reverse Curve to adjust the curve directions. If it’s the sorting of the curves that needs to be adjusted, you’ll need to use components related to List
Thank you!
I will try to figure it out
