I cannot find the way how to select a point on a given vector or a line. I would like to select and visualize the point on a line. Should I use projection. Is there a method for this?
(I already find how to visualize it by dynamic display)
Thanks,
Hey not sure what you mean with point on vector but there is a method for picking a point in the rhino docs:
obj = rs.GetObject("Pick a curve")
if rs.IsCurve(obj):
point = rs.GetPointOnCurve(obj, "Point on curve")
if point: rs.AddPoint(point)
I thought it is something, more complicated.
Thanks Lando!
Here is a RhinoCommon equivalent of the Rhinoscript method “GetPointOnLIne”, which is not yet implemented in python rhinoscriptsyntax…
import Rhino
def GetPointOnLine(prompt,ptA,ptB,track):
gp = Rhino.Input.Custom.GetPoint()
gp.SetCommandPrompt(prompt)
gp.Constrain(Rhino.Geometry.Line(ptA,ptB))
gp.EnableDrawLineFromPoint(track)
get_rc = gp.Get()
if get_rc==Rhino.Input.GetResult.Point: return gp.Point()
def TestFunction():
msg1="Pick point on line"
line_start=rs.coerce3dpoint([0,0,0])
line_end=rs.coerce3dpoint([1,1,0])
result=GetPointOnLine(msg1,line_start,line_end,True)
if result: rs.AddPoint(result)
TestFunction()
Thank you Helvetosaur.
This is a nice example. It makes more sense to understand IronPython.
