Hi, i want to know how to select every object with rhinoscript, like doing a Ctrl + A, i tried this whitout succes :
Dim arrObjects
arrObjects = Rhino.AllObjects
Rhino.SelectObjects arrObjects
Dim arrObjects
Try to use NormalObjects to avoid passing locked or hidden objects
Dim arrObjects
arrObjects = Rhino.NormalObjects
Does this help?
_Willem
Thank you for your answer but i finnaly figured it out minutes after i posted.
I just used Rhino.Command("ToutSelectionner") (french for SelectAll)
I think all you need to do is enclose arrObjects with parenthesis.
Dim arrObjects
Rhino.SelectObjects (arrObjects)
@DanBayn, his syntax is correct.
You can do this:
Dim arrObjects
or this:
Dim arrObjects
Call Rhino.SelectObjects(arrObjects)
– Dale
Yes, now I recall using Call. I guess I’ve been away from VB for too long.
you can also just use the first argument of Rhino.AllObjects to select without the need of calling Rhino.SelectObjects. Below will also include light objects (the second argument):
Dim arrObjects
Rhino.AllObjects True, True, False
_
c.
