Still no select simillar in Rhino?
I am cleaning a drawing to serve as a basis for some modeling and all the curves are in the same layer with different colors. I wanted to select based on the color, any way to do that?
Hello- SelColor is it.
Thank you for sharing those two scripts! Hard to believe that there are no such vital selection tools in Rhino by default. ![]()
Thank you!
Iāll bump this since Iāve been running into it in my own workflow. It seems like all of these scripts which select based on orientation to construction plane, print-width, geometry, etc. could be compiled into a SelSimilar command with a series of options. I second (third, fourth?) the wish.
FWIW My 2d Cad interface worked this way. It is one feature I really miss.
Here I have hit āselect filterā and then hit the = in the menu; clicked on the dimension. The left fields have been populated and then hit OK.
From there I can select every linear dimension (in this case) - select all
All Linear dimension in a window
or on a layer
Or select out a colour or layer for a subgroup of linear dimensions.
Hi Helvetosaur! Thank you so much for the rhino scripts they are super helpful! The āFindSimilarVolumesā one is pretty much exactly what I need, except that I canāt figure out how to change the script for it to have a higher tolerance with the size difference the volumes are allowed to have. Can you give me a hint were and how I can change it? Thanks a lot!
hi @Studio22 ,
in the start of the script you will find:
def FindSimilarVolumes():
#can tighten or loosen tolerance
tol=sc.doc.ModelAbsoluteTolerance
if you replace sc.doc.ModelAbsoluteTolerance with a number, you can define your own tolerance.
Chonk for Rhino 8 (paid plugin, has 30-day free trial) has a SelSame command, for some of the geometry types (Point, Curve, Mesh, Brep, Surface, Hatch and Block), perhaps this can help some of the users in this thread.
