I have a set of curves drawn in rhino (all on one layer) and I have this set of curves linked in grasshopper to a curve node. I am continuously adding to this set of curves, so I have to continue to “set multiple curves” in grasshopper to add my newly drawn curves to the set. I have everything on the same layer in rhino.
Is there a way to have grasshopper select my set from everything on that layer so I don’t have to keep going back to grasshopper and adding to my curves set?
I don’t think the leading and trailing asterisks are needed.
As to why my Untitled.3dm failed, it’s because the curves are on the ‘Default’ layer instead of the ‘crvs’ sublayer. I swear, I went over my changes very carefully, many times.
i just removed the asterisks and it does work, weird… i clearly remember making scripts a couple years ago where asterisks were required otherwise the layer wasn’t selected.
