Seeing Curves through Polysurfaces
Hello, I am having an issue with the rhino display options and none of my colleagues have experienced this before. The issue is that I am able to see the curves through closed polysurfaces and surfaces in every view setting. x-ray is ticked off nothing has been altered with and the objects are also close to the origin. Any help would be greatly appreciated please. Thank you.
Hi -
Have you tried the ClearDrawOrder command?
If that doesn’t do it, please run the Rhino SystemInfo command and copy-paste the result here. Also post a small 3dm file that shows this issue on your system.
Oh wow thank you so much! ClearDrawOrder command worked. Thank you.
