Yes! ![]()
I like SnagIt. Itâs not free, but itâs not expensive either. Use the TechSmith Fuse app on your phone, and you can take a picture and send it directly into SnagIt.
Dan
Native in Windows (since Vista) there is the âSnipping toolâ. Allows you to capture a window, rectangular or freeform portion of the screen. There are also a couple of (very) primitive markup tools⌠It has an automatic âCopy to clipboardâ option, so just select your screen portion and Ctrl+V direct into Discourse.
âMitch
Now look what Iâve done - thrown the thread completely OT. My bad. Apologies Dan. Can we get back ON topic now?
- itâs interesting!
After doing a lot of Googling today I found out two things. One, itâs pretty much universally accepted that the section line with arrows is a phantom line. The other thing I discovered is that there is very little evidence that a break line is required with a stepped section. I didnât see any mention of it, and where I did see illustrations depicting a stepped section, there were no break lines.
So I think it makes more sense to leave them out, and if the user wants to add them, they can do so manually.
So here is where it is at right now:
http://screencast.com/t/AAxeLhmg1p
Thanks,
Dan
Thatâs really neat Dan. Three questions:
Do you have to preset the hatch type, scaling and rotation for each object, or is that done automatically?
Is there any way to show whatâs âbeyondâ the section plane? I know thatâs a tough ask.
Can the resulting sections be saved out as DXF/DWG?
Itâs only applying âHatch1â but the angles and scale are randomly generated within reasonable limits to provide a difference. I also try to stagger the direction for mating parts. Of course, the user will most likely tweak these, so I didnât group them with the rest of the section. There is an option not to show hatches too.
I donât know how I would show whatâs behind. This is a true section. Itâs only curves. In other products, sections are illustrated as curves, but still contain the object. Thatâs why 2D in a lot of products is so bloated. Itâs not really 2D! I donât have the smarts to take this much further.
I suppose the sections could be exported. They are on a separate layer (I guess I failed to show that) so that layer could be exported. I donât think I would build that into the script as itâs easily done outside the script.
Thanks for the feedback. If I had the time and the brains, I could probably make this even better, but Iâm a little short on both.
Dan
It looks great. My query about export was more whether the output was exportable (i.e. curves & hatches) rather than exported. In other words, not a Display mode âtrickâ.
Hi Dan,
It looks great. Even if it isnât the âofficialâ way of doing things, I think break lines or slightly staggering the hatch makes it easier for me to read the section drawing. Otherwise you have to extrapolate the section line over to the section drawing.
Nick
No tricks here. Just simple curves.
If anyone wants to give this a try, here it is. Iâve included a simple template for loading the linetype. You can import it into your template file, delete the âdefaultâ layer that appears, and re-save your templateâŚ
âŚor if you already have a âphantomâ linetype, then just skip that step.
Iâve also included a âSectionLinesâ command for just creating the section line with arrows without actually cutting the section.
SuperSection project.zip (69.7 KB)
Let me know if you find a scenario where it doesnât work as expected.
Thanks,
Dan
The answer would be very. A lot of my work is millwork for architectural interiors and your tool would be immediately useful.
Just installed and started playing with it. This is going to be great. Simple things - like creating itâs own layer for the section data so it can be easily turned on and off are really well thought out.
Thanks.
Very useful and simple. Thanks!
Glad to see my quest for simply wanting to create annotation A B section has seen this thread develop, Looks very useful.
PC went dead on me, (one of the 4 memory sticks developed an error and HD caddy likewise, real nasty one to spot !) so I missed this until now, and 12 hrs of engineers fix time
back to my need though, what is best way of creating two arrowed section line A- B ?
Steve
Hi Steve, you can do all these functions with VisualARQ. Create section lines (including jogged sections), determine a direction, depth and a text for the section line, and later on create a section drawing of the model sectioned, including the projection of the objects in the background. You can also assign section attributes (line weights, hatch patterns, hatch color, rotation, etc) to any Rhino geometry, for display and printing purposes. This video shows how it works: https://youtu.be/JHk1vJ1r0wo?list=PL2FDEDC9F52CFEBF1
These commands are aimed to architectural projects, but they can be used for mechanical models too.
Cheers,
I just found this thread by mistake, but had JUST been wondering about section lines and lettering, b/c while the Section Tools plugin is fantastic, it seems to not have the option to create the section lines in a standard way.
EDIT: I havenât been able to make this work. ANyone still using this?
We use it here all the time. What do you mean by âstandard wayâ?
Just meant the way âSectionLinesâ in super sections looks (Letter w/ Arrow ⌠section line⌠Arrow to Letter) for the layout page.
Do you use SuperSection any more or just Section plugin?
I donât personally, but many others in the company use it daily. I havenât heard any complaints about it for at least a year.
Dan
