I’m importing the file from Adobe Illustrator to Rhino.
Illustrator UI has precision of 0.001mm. But AI stores data in points. Because of all the calculation and rounding - actual measures are off by 0.0001mm (if you import file into Rhino you can see actual tolerance and actual numbers that AI has created in 0.0000001 precision).
I don’t work in such a high precision, but if I would zoom things really close for inspection I can see misalignment, and it makes me crazy. As well, if I would need to scale things like 1000 times I would face real issue.
For example object that has to be exactly 455 x 4 mm I’m getting values like: 454.9999719 x 3.9997591
I know I could set Absolute Tolerance to 0.001 and move on, but it’s just not right.
Is it doable to create a Python script so it would automatically go through the objects and round actual values / save them?
I’m experienced in C++, so Python wouldn’t be that much hard to learn.
but I’m new to Rhino, so I don’t know its capabilities.
Could someone bring me on the right track?
FWIW, 454.9999719 is well within 0.001mm tolerance. This is more likely a function of floating point representation than bugs. This forum has already a multitude of topics lamenting and surprising people on floating points, arithmetic and precision.
For fun in Python do: print(0.1 + 0.1 + 0.1 == 0.3).
For all intents and purposes in the computer world 454.9999719 is exactly 455.
I would venture a guess that in this case there is no formatting of the numbers done. One reason for that could be that such a formatting also could introduce unwanted errors or misconceptions for the user of the state of the model. But I do not know the correct answer to this particular issue. Maybe @stevebaer or @dale know more about that?
Hello Dale,
What I mean is, if I set Display Precision to 0.001 It rounds only values in the text fields, but if I zoom to extreme in the view window, I see that lines do not match in my model.
For example if I have to two points one being 0.00007mm and other being 0.00005 placed on X axis. No matter what I set as Display Precision, on close inspection visually they are apart from one another.
Andrius has a point. Precise modelling is often not so much because the real world objects produced from it actually needs that kind of precision, but because it helps when points are at a precisely ‘defined’ location, and other points that are supposed to be at the same location should share the exact same coordinates.
This ‘jittering’ of points around a location is irritating, and invites for buildup errors that in the end can become relevant in production.
