My system is Rhino 6 SR13 C++ SDK 6.13.19058.00371
The member function of class ON_Xform,
void Scale(const ON_Plane& plane, double x_scale_factor, double y_scale_factor, double z_scale_factor);
the result of the scale operation is seem incorrect, but it is corrent in Rhino 5 C++ SDK.
I exchange the parameters y_scale_factor and z_scale_factor to get the correct result.
Is it a bug?
Hi @john12,
This works as expected:
CRhinoCommand::result CCommandTest6::RunCommand(const CRhinoCommandContext& context)
// Define points for unit box
ON_3dPointArray points;
points.Append(ON_3dPoint(0.0, 0.0, 0.0));
points.Append(ON_3dPoint(1.0, 0.0, 0.0));
points.Append(ON_3dPoint(1.0, 1.0, 0.0));
points.Append(ON_3dPoint(0.0, 1.0, 0.0));
points.Append(ON_3dPoint(0.0, 0.0, 1.0));
points.Append(ON_3dPoint(1.0, 0.0, 1.0));
points.Append(ON_3dPoint(1.0, 1.0, 1.0));
points.Append(ON_3dPoint(0.0, 1.0, 1.0));
// Create unit box and add to document
ON_Brep brep;
if (nullptr == ON_BrepBox(points.Array(), &brep))
return CRhinoCommand::failure;
context.m_doc.AddBrepObject(brep);
// Create scale transformation
ON_Xform xform = ON_Xform::ScaleTransformation(ON_Plane::World_xy, 6.0, 4.0, 2.0);
// Scale unit box and add to document
brep.Transform(xform);
context.m_doc.Redraw();
return CRhinoCommand::success;
Feel free to post any code you cannot make work correctly.
– Dale
ON_Brep brep;
if (ON_BrepBox(points.Array(), &brep) == NULL)
ON_Xform trsf = ON_Xform::IdentityTransformation; trsf.Scale(ON_xy_plane, 6.0, 4.0, 2.0);
ON_Brep brep1 = ON_Brep(brep);
ON_Brep brep2 = ON_Brep(brep);
brep1.Transform(xform);
brep2.Transform(trsf);
context.m_doc.AddBrepObject(brep1);
context.m_doc.AddBrepObject(brep2);
//brep2 is incorrect
@john12, the version of ON_Xform::Scale you’re calling has been deprecated (obsolete). Use the static version that I demonstrated earlier.
– Dale
