RunPythonScript, choose interpreter to IronPython 2 Rhino8
Hey there,
I want to use the RhinoCAM plug-in and wrote a python script to create g-code when executing this script. In the editor everything works fine. If I type
_RunPythonScript <Filepath> _Enter
in the commandline the error
no module named mecsoftcamapi occurse.
At the beginning of the script is the first line
#! python2
Is there a way to change the interpreter to IronPython2 when using the command _RunPythonScript??
Thanks in advance.
-Stefan
how does this solve my problem that the _-RunPythonScript uses the Python3 interpreter??
The command should use IronPython 2 that I can use the RhinoCam plug-in
I thought RhinoPython was still IronPython2, and Python 3 was only usable from Grasshopper.
Perhaps the problem is that Rhino is failing to find your script, or your script is failing to find mecsoftcamapi ? What have you set the module search path to?
I solved the problem. Not the interpreter is the problem. As James Parrott said the module mecsoftcamapi was not found. I did not know that the _EditPythonScript editor is different to the _ScriptEditor. I had to enable the searchpath to the module in the _EditPythonScript editor too…
