I am developing a plug-in that generates some analysis files for OpenFOAM, which is a CFD software that runs on Linux. At the moment I have a break in my automated work flow since I need to manually transfer the files generated with Grasshopper to my computing cluster. The transfer can be done using a terminal or a powershell and I am therefore looking into possibilities of doing this directly in Grasshopper.
I was thinking that I can write a component that takes in the path to the files that I want to transfer from Windows and a path on my cluster to where I want to transfer the files to and then opens up a shell and perform the required commands.
Does anyone know if this is doable? And if so, any hints on how to do it?
Yes it’s doable through C#/Python/VB. I’d recommend to perform the file action in your script, rather than use terminal and call a script. For the latter, you may be looking for Process.Start()
Exactly - My idea is that when a condition is true (eg a Button) my component will automatically call the necessary commands in the background (or shortly open a CMD/Powershell and perform the commands automatic) to transfer the files.
I am not a super advanced coder so I would need some help with Process.Start() as you suggest. How can I use this? Or can you guide me to some documentation?
