iRhino3D WIP (8.0.23123 (11.1.1) - May 3) available via Testflight has a CommandLine
This is an unfinished feature with some known issues and many unknown ones. It may also crash on you unexpectedly, so use at your own risk
For serious work, always use the Appstore version of iRhino3D.
Enabling The CommandLine
The command line is hidden by default (for good reasons). Here’s how you can enable it:
- Tap the gear icon on the bottom right corner to go to Settings panel
- Go to Extra tab
- Enable CommandLine
- You should now see a keyboard icon on the top right corner
Running Commands
Tapping the keyboard icon brings up a keyboard with an integrated command field where you can type a command.
You can run the command by tapping the return key or one of the suggestions.
While a command is in progress, following controls are presented:
- Finish or Cancel the command.
- Toggle Grid Snap and OSnaps (OSnaps currently have no effect)
- Open command options panel
