rs.GetPoint() won't accept a pasted coordinate but "_Point" will
Hi @dale, I use rs.GetPoint() to get a point (obviously) but sometimes I know the coordinate and have it copied to clipboard and want to paste that in instead, but that doesn’t work.
But this works for the command _Point, so I workaround this by first adding a point and then snapping to that with rs.GetPoint(). But that isn’t a smooth workaround, so could you add the ability to paste a coordinate for rs.GetPoint()?
Let’s say I want to use this coordinate in the script: 10080,20085,0
The strange thing is that if I type it in then it works, but if I paste it then I get this error message:
Unknown command: 119080,1191385,0
Please try it out with this super simple example
print rs.GetPoint()
(I have a system where I set up a reference point as a local origin for architecture, and I often want to copy this data to another file)
Hi @Holo,
Any better?
#! python 3
import Rhino
import scriptcontext as sc
def Test():
    rc, point = Rhino.Input.RhinoGet.GetPoint("Location of point object", False)
    if rc == Rhino.Commands.Result.Success:
        sc.doc.Objects.AddPoint(point)
        sc.doc.Views.Redraw()
if __name__ == "__main__":
    Test()
– Dale
Thanks, that works fine!
And if someone finds this, I changed it to:
if not rc == Rhino.Commands.Result.Success:
    print ("Error: No valid point chosen")
    return False
Please see if you can update the rs.GetPoint to act in the same way.
