rs.GetObjectEx() seems to be broken in 8.14 IronPython
Hi all,
I’m getting the following error message with rs.GetObjectEx() in IronPython in Rhino 8 SR 14:
File “C:\Users\axelj.rhinocode\py27-rh8\site-rhinopython\rhinoscript\selection.py”, line 333, in GetObjectEx
File “C:\Users\axelj.rhinocode\py27-rh8\site-rhinopython\rhinoscript\selection.py”, line 276, in init
NameError: global name ‘_CustomGetObjectEx__CustomGetObjectEx’ is not defined
IronPython.Runtime.UnboundNameException: global name ‘_CustomGetObjectEx__CustomGetObjectEx’ is not defined
I’m using the ScriptEditor
Is this a known issue?
Many thanks
Axel
I don’t see that here. Can you try resetting runtime?
Hi Gijs,
I restarted Rhino and did some more digging.
The error only shows up when I pass a list of guids through the objecs= option of rs.GetObjectEx(). It’s a Python list (not IEnumerable or some other .net list). This used to work in R7.
arrow_guids = rs.ObjectsByLayer(self.const_arrow_layer)
msg = 'Pick arrow shape'
flt = rs.filter.hatch | rs.filter.surface | rs.filter.mesh
arrow = rs.GetObjectEx(msg, filter=flt, preselect=False, select=False, objects=arrow_guids)[0]
Regards
Axel
@axa got it, thanks for reporting.
RH-85381 rs.GetObectEx fails when objectlist is supplied
Thank you, Gijs
A
RH-85381 is fixed in Rhino 8 Service Release 16
